Old 12-28-2009   #4
blackrosenova400
blackrosenova400's Avatar
Re: Wtb 1990- early 91 22spline awd trans
Well get er out, at this point its best to pull it out, inspect you clutch. It probably needs syncro replacement. I can do syncro replacement, there only 20$ a piece. So it would be 40$ to replace 1st and 2nd gear syncros if that the problem. But they would need to be ordered and I have to bring the counter shaft to work after pulling the trans, to use the shop press and replace them. You could also have a bad fork but only opening it up can you tell. If it is a bad fork or rail, I have a couple of them around.
