Old 01-08-2010   #11
Re: Power Steering FLuid Foam
Originally Posted by Alpha D View Post
That sounds like it could cause some serious damage if not taken care of.
So i should check for the rod asap then. Are those rods readily replaceable? Or is that going to be more of a job that should be left for a pro?
Thank Everyone for the input!
That rod has a big hex on it that is used to turn it, should be easy to do by yourself with a wrench or socket. Just get it snug and don't over tighten as it is aluminum.
