Old 01-08-2010   #16
CarPsyco84
CarPsyco84's Avatar
Re: Upgrading from NGK BPR9ES from BPR6ES.
I would check the gap of your current plugs first... it should be somewhere in the .026"-.030" range. I worked on a gst one time that someone had put the NA plugs in there gapped at .046" It ran fine till it started making boost, then it would buck and miss bad.
-When in doubt, Moar RPM.
