Old 01-16-2010   #23
Re: This is fu*k up
Moved to tech forum:
Without the throttle body hooked up, the only way for air to bleed off into the crankcase would be through the turbo seals into the oil pan. There is no other connection to the crankcase other than the turbo drain with the way it was done in the first post. The BOV takes its boost/vacuum sources from the intake manifold and turbo after the compressor. Even if the BOV is blown or leaking, it wouldn't get into the crankcase, it would leak into the intake manifold and go out the throttle body or straight to atmosphere.
