Old 01-16-2010   #25
CarPsyco84
CarPsyco84's Avatar
Re: New and need some serious help
Make sure its not locked from the column lock when you pull the key out, otherwise if the pump is taken out, you gotta have some muscles to turn the steering wheel cause of the no power assist. If you want the power steering back, I'm sure someone on here has a power steering pump around they would let go for cheap,
-When in doubt, Moar RPM.
