Old 01-17-2010   #24
Re: This is fu*k up
Moved to tech forum:
Without the throttle body hooked up, the only way for air to bleed off into the crankcase would be through the turbo seals into the oil pan. There is no other connection to the crankcase other than the turbo drain with the way it was done in the first post. The BOV takes its boost/vacuum sources from the intake manifold and turbo after the compressor. Even if the BOV is blown or leaking, it wouldn't get into the crankcase, it would leak into the intake manifold and go out the throttle body or straight to atmosphere.
Good discussion.
First off, the way you're doing it by disconnecting the UCIP from the throttle body is not how I normally do it, but it is good at isolating an issue with a leaky BOV and/or turbo seals.
As, is, answer these questions:
1) Is there any air coming out of the BOV?
2) Does the system hold any pressure at all? Or does it all just completely blow out of the valve cover breather? You should at least be able to build it up to 10-15psi, unhook pressure, and have it sit there while you look for leaks.
2a) if you block off the valve cover breather w/ your finger, does it leak anywhere else? Just a small amount of boost would be a fine test, 3-5psi.
Next, hook up your UICP to your TB again and do the test. Again, does it hold *any* boost or does it all just leak out instantly?
Side question: did you have shane do a leakdown test? That should really let you know if there's a problem with your head.
