Old 01-18-2010   #20
Re: CBRD/Blouche BBK/BBK Lite turbo for Evo 8/9
Hrm, I'm liking these results, on cali-piss too! speed density and a non-cdi COP seem to be a good ticket for pump gas. :P
Originally Posted by GST Motorsports View Post
2006 Evo 9 SE
Mods:
AEM Short Ram Intake
Nisei IC piping
Nisei 3.75" Competition Intercooler
APS Twin Vent BOV
Mil.Spec 65mm Throttle Body
Mil.Spec R2 Intake Manifold
Hondata IM Gasket
Kelford 9-TX280 (280/276) MIVEC Cams
Cosworth Valve Springs
ARP Head Studs
Stock Bottom End
Sparktech Non CDI C.O.P.
EGR/Charcoal Canister/Fuel Pressure Solenoid Removed
Forge Upgraded WGA
CBRD BBK Full Turbo (Mil.Spec Ported)
Stock Exhaust Manifold (Mil.Spec Ported)
TiTek v1 o2 Housing (Mil.Spec Ported)
MXP 3" Downpipe
RRE Stealth Exhaust
RRE Rally Cat
Walbro 255
FIC BlueMax 1450cc Injectors
EVOX 3 bar Map Sensor
GM AIT Sensor installed in Intake Manifold
GM 3 Port (ECU Boost)
3" AEM Intake filter
Cone filter
Stock ECU
Tephra V7
91 and E85 tunes
This Evo made 386 whp on 91 with the MAF, which already broke the standing BBK Full 91 oct record on our dyno (was 369). I took off the MAF, put a straight cone filter on and went to tuning the car on Speed Density. To my amazement the car responded really well to the SD conversion.
+17 whp peak gains to make 403 whp on straight California 91 oct. This is usually reserved for 35R+ turbos on our dyno. Now, a 100% stock looking turbo accomplishes this task.
403 whp / 330 wtq
24 psi
Next was E85 and it made a very healthy 455 whp at only 27 psi (car is tracked)
For reference:
Highest power on a Evo 9 stock turbo so far on our dyno is 403 whp / 402wtq (E85). This had the car doing a 11.4@120 mph, full weight, street tires, 300lb driver.
320-330whp will do 11.9-12.0 @ 115ish with a really good driver, full weight Evo.
Stock 03/04 evo = 190-210whp
Stock 05 evo = 210-215whp
Stock 06 evo = 220-230whp
Stock 08 evo = 215-230whp
Stock 09 Ralliart = 190-199whp
http://forums.evolutionm.net/evo-dyn...tephra-v7.html
