Old 01-21-2010   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: 4g63tcrazy's new setup for 2010
Now I needed a wastegate off the o2 housing. I got a hold of 2bar1g (mitch) and picked up his HKS 40mm wastegate and 3" o2 housing for a good price.
Painted the top of the wastegate black to go along with my "theme" of red and black.
After some test fitting I found that I needed a lot more room for the turbo to fit. As you can see the manifold was really close to the head and the compressor housing hit the waterpipe and motor mount..
Searched the forums once again and got a 1/2 thick spacer which made everything fit perfectly!
That's about all for now. Need to get some sleep. I'll update more later.
-1990 Mitsubishi Cyborg 4WD-
