Old 01-25-2010   #1
FP Red, recently rebuilt
Since it looks like I'm selling the V, I'm going to sell my FP Red turbo on the Talon and pick up a 68HTA for autocross and just more insta-spool fun.
Complete bolt on, uses the standard mitsu oil and water connections. For those that don't know, the compressor is a garrett 60-1, and the exhaust is a clipped td06h wheel.
I had it rebuilt this summer by Bob at MAP, used the monster thrust bearing and a new center section. There is less than 1000 miles on the rebuild (no shaft play). Also the turbine housing is ceramic coated inside and out. Setup for wastegate on o2 housing.
I would post pics, but it looks like every turbo. It's pretty much in perfect shape, no bent fins or anything. Makes good power, 412 at DB at 28psi, 360whp at 20psi. I don't want to take this turbo off until somebody has money to buy it.
Asking $850 obo.
Old 01-28-2010   #2
plow420
plow420's Avatar
Drives: 96 eclipse gsx
Re: FP Red, recently rebuilt
can you include the wastegate / o2 housing?
plow420 is offline   Reply With Quote
Old 01-28-2010   #3
I was planning on using that for the next turbo, but I suppose I could do an internal gate setup. I would charge more to include the o2 housing and wastegate though.
