Old 01-26-2010   #11
Re: 1991 talon 500 hp project
Jasons car quest to 500 awhp --- Which Dyno?
5.methaol injection kit stage 2 $ 300 ---Stage 2? Which brand? Thats pretty cheap unless its a used kit. Go with E-85, you will be much happier.
10.rewire fuel pump and run bigger lines $80 --- bigger lines aren't going to be neccesary
11.brian crower cams 272s $360 ---look for HKS's you will be MUCH happier
12.valve springs and steel valves $400 ---you can get FP beehives for cheaper than that.
17.lph 255 have installed ---Make sure its the HP version
20 fp evo3 16g have installed ---good luck getting to 500 with that unless you're the next Curt Brown
Also, you HAVE to clean up the grammar in this thread if you expect much help man. This thing is seriously hard to read. Just trying to help ya out. Good luck with everything!
