Old 01-26-2010   #12
Re: INSTALLED: Evo IX SpoolinUp COP & Denso IKH24 plugs
It's been said that running these coils with the larger gap will let you run more boost on pump gas, have you seen that at all shane?
I don't know. Who runs pump gas in MN besides you, now that Kracka moved away?
I could possibly see some 28psi on the BP 93 pump gas that we have now. With the 91-92 swill that most of the gas stations around here sell, we usually had to pull so much ignition timing when we tried to run over 25psi that we didn't gain any power.
I could also see the the stronger ignition doing away with any light misfires under higher boost, the kind you really can't hear or feel that much but get picked up by the ECU as false knock or causes real knock(cars often detonate during misfires).
