Old 02-01-2010   #24
Re: I think I found it.
He wasn't blaming me. I was the last one to touch the cam gears when I moved the cam gears on the dyno from the DSM dowel pin hole to the Evo dowel pin hole, which ended up picking up some decent top end power, but it was still way down on power and motor was making weird noises(probably the idler pulley he found). Best bet might be to put some stock cam gears on it and line everything up properly/tension it properly with the timing belt cover off.
