Old 05-01-2004   #2
1600 deg F is about as hot as you want to get. Anything hotter will start melting parts (pistons, valves). 1400 deg F is normal operating temp under cruise. I would think you could tell if you car was really idling at 1400rpm. Recheck your connections. The tach is probably reading incorrectly. You might just have to disconnect the afc to see if the tach problem goes away.
