Old 05-01-2004   #5
illz
Originally posted by 1ViciousGSX@May 1 2004, 09:13 AM
1600 deg F is about as hot as you want to get. Anything hotter will start melting parts (pistons, valves). 1400 deg F is normal operating temp under cruise. I would think you could tell if you car was really idling at 1400rpm. Recheck your connections. The tach is probably reading incorrectly. You might just have to disconnect the afc to see if the tach problem goes away.
hotter than 1600f will not start melting parts. 1600f/900c is as hot as you should be seeing because any hotter indicates the ecu is pulling timing and more of the flame front is shooting through the manifold/less of the explosive energy is pushing the piston down and more is firing through the manifold. when you are at full throttle and EGTs are climbing to 800-850C then spike to 900c it's because the motor knocked, ecu pulled timing, and hotter shit fired past the probe.
for example, with dsmlink v2 and antilag, ill see 950-1000c+ EGTs while spooling the turbo at a stop with antilag retarding the timing. it's not melting shit, it's just firing flaming gas through the manifold and turbine.
