Old 02-15-2010   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Spyder in the making
Umm....I guess you can say it mounts almost like the stock turbo manifold. All I did was bolt on the mani+turbo and the clearance worked out fine.
Do you have a stock manifold to compare it to? Could you measure the distance from the head flange to the turbo flange? I'm trying to decide if I should get an FP manifold or not cause with the DNP I have now I have to run a spacer to clear the waterpipe.
-1990 Mitsubishi Cyborg 4WD-
