View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 02-27-2010   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Dave's Evo X Build
Its an alumium pipe, pre bent kit ftw? A little bit DIY? local welder/shop?
You ballers are out of control.
Thanks for the info on the turbo, 410@27psi sounds damn good compared to those other charts and he can still do another 10+psi.
Good luck I hope you break 460-470 that is nuts.
The most I will run the red to is probably 33psi. The key is going to try getting the turbo to hold more boost up top. Mine is falling off a little more than expected. I don't think we had the wgdc's turned all the way up yet though. Plus with the leak who knows.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
