Old 03-06-2010   #6
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Re: head gasket?
Originally Posted by CarPsyco84 View Post
1st thing is make sure it has enough oil in it, then make sure it still looks like oil. Low oil pressure usually isn't caused by a blown head gasket, ususally means your bearings are loose, oil pump is worn out, oil pickup is partially blocked, or your oil pan is caved in, or any combination of these.
so how can i tell if the bearing are loose, oil pump is goin out, or the oil pickup is patially blocked?
mitsukid124 is offline   Reply With Quote
