Old 03-06-2010   #20
CarPsyco84
CarPsyco84's Avatar
Re: Adjustment or Something Else?
It's pretty common to have the clutch assembly so loose that the master isn't long enough to take up all the play, at which point there are 2 options, make the threads on the master longer or fix the pedal. Option 2 is a PITA unless theres a trick to welding them in the car.
-When in doubt, Moar RPM.
