Old 03-14-2010   #17
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: How much psi can stock internals hold?
The compression of your motor also matters. The lower the compression, the easier it will be to get a good (higher boost) tune on pump gas. Depending on the compression/condition of your motor, I am guessing you could run 18-25psi pump. Having 40k on the motor does not mean it will be in good shape either.
7/25/09
