Old 03-19-2010   #1
Re: LingLing's Project Thread
The nut that holds 5th gear on can work its way loose, and then worse case scenario fall off or something. I guess a symptom is popping out of fifth.
What route are you going with the tranny?
Old 03-19-2010   #2
blackrosenova400
blackrosenova400's Avatar
Hes picking up another this weekend and Im going to inspect it and swap thru shafts for the t-case if needed.
20g Mafia
Old 03-19-2010   #3
I guarantee that's what happened Ling Ling. Here is a pic of that same nut from my 1st tranny. Except in mine, the nut actually sheared right off with a piece of the shaft still in it.
