Old 03-22-2010   #1
Re: 1g Dual piston Calipers.
2g's use as banjo bolt so you would need to change the brake lines also. all others are screw in brake lines and are a direct swap in
Old 03-22-2010   #2
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
That is only true for the 95's I thought...
Old 03-22-2010   #3
Correct. and with the amount of rust on this car i really dont want to mess with swapping brake lines, yet.
