Old 03-29-2010   #11
Re: 91 Galant VR4
I suppose I never did post up a complete mod list, so here is updated version.
Engine:
2.0 block bored and honed .040 over
wiseco 9.25:1 pistons
Crower rods
stock 2.0 crank, balanced and polished
King std sized rod and main bearins
ARP main studs, line bored and honed with pins in the main caps
removed balance shaft
Cometic HP head gasket
A1 L19 head studs
major head port work
1mm over ss valves
shimmed crower valve springs and shaved down chrome moly retainers
Crower 288 cams
Crower cam gears
Greddy blue timing belt
Turbo setup:
Garrett standard bearing GT4202 with 1.01 divided housing (I will up grade to the Billet 4202 and Tial exhaust housing later)
custom divided top mount T4 exhaust manifold
custom REEF drag SMIM with 3 injectors per cylinder
PTE WTA intercooler core with custom end tanks 3.5" in and out
custom wta intercooler heat exchanger, 4 gallon system with ability to add 1.5 gallons of ice
twin tial 38mm waist gates
4" tube style exhaust
10lb NOS bottle, will be a 75/100 shot dry in the TB or 100 shot direct port dry
Fuel:
8 1600cc injectors (2 per cylinder) as secondary injectors
4 450 or similar injectors(factory location) for low throttle
fuel pump/s will be aeromotive A1000, aeromotive eliminator pump, or 4 Ford GT fuel pumps(330lph)
-10 aeromotive AFPR
1/2" aluminum hard line, feed and return, -10 SS braided line from pump/s to hard line and hard line to fuel rails and AFPR
pump gas fuel E-85 3x psi
race gas E98 or C/Q-16 5x psi
AEM EMS, 5bar map, GM IAT, secondary injectors ran from a injector driver box to split the secondary injector signals(4) to run the 8 1600's.
Drive train:
shep stage 4 or similar tranny
twin disk clutch or equal
stock tcase
stock 3 bolt ring and pinion
4 bolt LSD diff
stock 4 bolt rear axels
stock front axels
solid mounts on just about everything
Tire option 1 click
Tire option 2 click
tire option 3 BFG drag radials 275/50/15
Rim will be a Enkei RPF1 or similar 15x8 4x114.3
chassis:
8 point 1 5/8" .083" wall DOM chrome moly roll cage
tied in front tubular frame structure retaining factor strut location and engine mounts
1 5/8" .083 dom chrome moly dash bar
added 2" x 3" .125" wall mild steel frame rail for main hoop and D bar mounts
Kirkey race seat w/ custom mounts and 5 point G force safty harness
I will buy a Hans device when things start to get fast
K sport coil overs for a 1g
lexan rear window
removable front clip
removable trunk lid
stock breaks
EBC red pads all around
slotted rotors up front
SS break lines
new ball joints and tie rod ends
custom fabricated strut bars
The rolling chassis weighs in at 1500lbs
Total race weight with drive should check in at around 2400lbs
The fastest this car has gone is 11.66@122, as posted on DSM Times. This was 3100lb race weight and about 440awhp.
Any other questions or if you want to see more/different pics of something let me know, thanks for looking.
Don't forget last "go around" the car made 660+awhp easily on the last setup, never saw track duty.
