Old 04-07-2010   #6
Re: FIC 1600cc injectors, AFPR + install kit
Originally Posted by stikx View Post
xl3e-c9a. I searched it, came up with bosch 160 lb/hr injector.
280150846, this number is on the other side of the injector.
Bosch
0280150846 - 1650 cc -white tops
( 14mm top, 16mm bottom )
## unusual 4.5 ohms
is reputedly similar as the earlier blue
[ but alcohol, CNG and LPG vapour compatible ]
( some tests rate them as only 1300 cc )
the blue is a ford USA motorsport item, hence the indy term
the white is a specialised alcohol injector, with heavy pintle , a little slower than the rest
Ford PN:
Ford XL3E-C9A / Ford XL3Z-9F593A
motorcraft - MICM4980
Information taken from 3si.org. User that posted info is donniekak. Heres a link to the thread: http://www.3si.org/forum/f1/guys-wan...ectors-468684/
