Old 04-07-2010   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: ECU cap's related question
I can replace the caps also. Not to hard and I can show you how its done.
Did it to my 90 ECU
Replacement caps are much better. I actually recommend replacing the caps on the 1g ecu's even if you are not having problems. almost about 20 years old and those cap will leak...
I soldered my standalone ECU. Hope that give me some credit.
Old 04-11-2010   #2
Gravy
Who's this guy?
I may need some done at some point too, have to do some reading on the forums about the 3/s ECU computer. But the caps didn't look the best in that beast. I'll send you a msg if i need something done Andrew.
