Old 04-21-2010   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Cutting out/studdering at 3k-4k
Wonder if it would attach if you Zipped it.
Dumb question, but what version of Link are you running? I ask because it sounds like it's only doing it under a little bit of load. You say it has no issue when you use light throttle, only when you give it a good bit of gas. Just wondering if you're using V3, and maybe something in your load tables got hosed up.
I'm running v3 ecmlink. I tried tuning my a/f in using the load table back before I pulled the head off. I couldn't get a feel for it so I stopped. I went into my previous logs and set all the settings back to original.
I have another coil pack sitting in the garage along with a transistor if the other guy falls though and you want to try a different parts.
Hope its something easy though and not wiring.
iwanta4g63t on here is stopping over tonight and were swapping out the transistor and coil pack
Hopefully you've already checked this, but have you checked compression? I'd think that wouldn't be it though...
I'm actually about to go check compression right now.
-1990 Mitsubishi Cyborg 4WD-
