Old 04-28-2010   #11
Re: Swifty's never-ending project thread!
Its ok swifty. I do recall the conversation but it was more of a pondering as to whether to reuse or not to. which he came to the conclusion that he would not be reusing. I am reusing mine, and i will post up the compression tester results and we can compare. But i have always reused my metal head gaskets, never taken out the rivets though that seems pretty extreme. Maybe next time ring the block and head and not have to worry about expensive head gaskets.
Speaking of which have you done a compression test?
I just palmed face so hard I am now bleeding and partially blind. You have got to be joking. Please tell me you are.
Compression test isn't going to prove jack shit unless you absolutely fucked up the head installation or the gasket is severely messed up. When the cylinder fires it puts more pressure on the head gasket than just cranking the engine over will ever do.
