Old 05-07-2010   #1
Garage clean out
Everything is now OBO, no reasonable offer turned down.
I am trying to weed out a little, so I can finish my Galant build some time this decade. Here is a list and some pictures of items I would like to sell. Prices as marked, or best offer. I prefer cash in hand, but I do have Paypal.
PM or email me if you want to buy something: GalantVR41062@yahoo.com
Here are the pictures and I will update or add stuff as needed.
This is the for sale list:
C-16 race gas, I have 25 gallons this has been sealed and purged with argon if gas was removed. $10 a gallon or $200 for the 25 gallons and the barrel obo
Eagle 5900 MBB rods with JE 81MD4 pistons, 1 rod spun a bearing, the main bearings were in upside down thus no oil to the rods, and they are missing 3 rod bolts. ::: sold ::::
8 ARP 2000 Eagle 1.5 rod bolts, new from ARP. $40 obo
6 mild steel laser cut T4 turbo flanges. Brand new from PTE. $20 each or $100 for all 6 obo
5 t4 steel turbo gaskets $5 each or $20 for all 5 obo
1 T3 steel turbo gasket $5 obo :::SOLD::::
3 laser cut stainless steel 7cm mitsubishi turbo gaskets $20 each 2 left ::: 1 sold ::::
5 7cm factory turbo gaskets $10 each or $40 for all 5 obo ::: 2 sold :::
1 stainless steel stamped mitsu bolt on turbo to o2 housing gaskets $20 each obo
1 stock evo manifold to turbo and turbo to o2 housing gasket set $10 obo
I have a box full of 1/2" thick stainless steel mitsu bolt on O2 housing flanges a little clean up work and holes drilled is all they need. $20 each or the hole box for $260 obo
Car quest ps belt 9265 $5 obo
stock 3s throttle body minus TPS sensor $20 obo
brand new in box MSD tack adapter part number 8912 $60 obo
Stewart Warner 2 1/16" black face 30/40 boost gauge, used $20 obo
Stewart Warner 2 5/8" white face tranny temp gauge brand new in box $40 obo
Stewart Warner 2 5/8" black face 30/40 boost gauge brand new in box $40 obo ::: Sold ::::
various NGK iridium spark plugs for a 3/s or dsm/evo and 1 set for a neon $5 each obo
universal aluminum shift nob $10 obo
stock dsm coils I have 3 good sets and 1 missing a plug $20 each obo
2g mas missing the lower middle honey comb $40 obo ::: on loan::::
2g speedo gear/sensor $40 obo :::: SOLD ::::
longer clutch slave cylinder rods 3.650" in length the bag is marked FWD $5 each or the $40 for the hole bag (15)
the never ending pile of unmentionable blue EGR block off plates with socket head cap screws.... ::: sold ::: 1 to Hill and the others go down range
Blue Greddy type RS thread in nozzel $10 obo
SSQ stainless steel weld on flange $10 obo
Brand new ZEX nitrous fill station w/ stand for gravity feed tank $600 obo :::: SOLD ::::
Red Line engine race oil I have 1 case of 40wt race engine oil $10 a quart or $100 for 1 case
1g dsm 1 3/4" .125" wall mild steel DOM main hoop $140 obo
BHJ 2.0 torque plate, used w/ box and chrome moly spacers $140 obo
BHJ 2.4 torque plate, slightly used and good up to a 2.7 hybrid 4g engine $140 obo
1g awd starter w/o cables $20 each
K sport adjuster's and 1 spanner wrench $20 obo
garrett wastegate actuator, universal fit $40 obo
New items for sale:
sparco universal seat slide brackets, they look just like these http://www.amazon.com/Sparco-00493-T.../dp/B000ECJ17M I have 2 sets $50 each or $80 for the pair obo
1g dsm copper radiator, its a little beat up but no corrosion or leaks $40 obo
10 turned down balance shafts for the 4g63 engine. The shafts look just like this http://www.cimotorsports.net/motor-s...-kit-4g63.html $80 each obo ::: 2 SOLD ::::
