Old 05-09-2010   #1
rapedbytheeves
Drives: 1990 eagle talon tsi
Angry big problem car wont start... please help ASAP!
okay guys got a problem and ive tried looking for a solution before posting this and havent been able to find anything so here it goes... just got my 1990 eagle talon tsi about a week ago, had to replace all main brake lines, water outlet, tstat, and a few other things. the problem im having now is fuel related. the previous owner had a long wire connected to the fuel pump harness. the black with white striped wire which is the power wire i believe. it wasnt connected to anything and was just looped in he must have cut all the other wires too and did a hack job on them, before i touched them i started the car, after i cut them and rewired the harness matching the colors i tried starting... nothing, checked the wires again just to make sure and still nothing. then i cut them again striped, soldered and shrink taped em. still nothing. so i thought maybe they touched something and blew a fuse. however there are no fuses for the pump. pulled the pump out and tested to see if it was pumping and it was, put it back in and wired a 12v constant to a switch and tried running the pump that way and starting the car.... nothing. so i hooked up the harness and tested for volts. with the key on the ON position it showed about 0.08v with the car cranking it shows 7.6v-8.0v. i have spark and i believe fuel is getting to the rail. what else could it be??? if the fuel relay was shot wouldnt there be 0v to the pump? something like this happened to my girlfriends civic when the pump wasnt pushing out enough psi but it still started for about 3-5 seconds then died. my car doesnt even want to start. it just cranks. all my fuses are good checked over them twice. checked the wiring like 5 times. i cannot find anything on this on the net PLEASE HELP!!!!
rapedbytheeves is offline   Reply With Quote
