Old 05-12-2010   #11
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: MitsuStyle.com Spring Dyno Day--Sat May15th @ DB Performance
Give me a call or text and we can work something out. (763) 286-1540
I will give you a call tomorrow night from my work cell: 571-242-3094
Find out if there is something we need to do to put the E55 into a dyno mode.
I looked around and it can be put into dyno mode by pushing some buttons on the steering wheel. I can PM you the instructions or just bring it with the car to the dyno day. It will need to be run in manual mode as well, but that function is easy to use.
The main issue if it isn't done in dyno mode the car freaks out as it sees the rear wheels moving faster than the fronts. Dyno mode disables traction control and ABS.
7/25/09
