Old 05-19-2010   #11
Re: Swifty's never-ending project thread!
Seriously, WHO THE FUCK USES A 270 DEGREE THRUST BEARING FOR A TURBO THIS SIZE!?
Since the pics are not quite clear, comp wheel is done, backing plate is ground away/done, comp cover..done. Thrust bearing had too much in/out shaft play, wore away, had more play, then the turbo comp wheel sucked itself straight into the comp cover. Everything is fucked. Turbo is now an expensive paperweight, till I figure what the fuck to do.
