Old 06-05-2010   #2
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Re: Removing Valve Cover Baffles?
Remove for welding and cutting but then put back after you clean up all material. Drill and tap where you have to drill out whatever it is that is holding the baffle to the cover and use small screws with loctite to put back in.
Mwolf83 is offline   Reply With Quote
