Old 06-09-2010   #5
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 2.4 n/t?
the 2.4 with a DOHC is a common build. There is a lot of info around for how to do that.
short story, if you are using the 6 bolt 4g64 block, you would need aftermarket pistons that would lower the compression. if you would use the stock pistons you would get a 12:1 compression ratio.
You would also need a DOHC 4g64 timing belt and cam gears.
