Old 06-23-2010   #18
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Perkul8r's Rebuild.
Only 2 valves had a very little mark on them that looked fresh, And the piston head had some very slight marks in it also. I am also talking about the head off my parts car talon, not the laser head in the pics. I know there are more than 2 bent on that one.
It looks like for some reason the number 1 piston/rod assembly has come apart from the crank. When i pulled the head the number 4 piston is at TDC, the middle 2 are down and i could push the number one piston down by hand. So i am replacing the 2 valves that have the slight marks on them from the number 1 piston. Its the 2 exhaust valves. And i had a local shop check it out and only one valve on that hole doesn't seal all the way. But i was just gonna replace the 2 anyway. I hope that makes sense. Sorry if it dont.
