Old 06-30-2010   #1
Re: no boost building. Please help
Well a mod list would be a bit of help, I read your post a few times and really don't get what you are talking about, the problems or symptoms you are describing don't have much to do with each other. Fuel pressure and boost are generally not really related.
If you are not building boost at all (from the turbo) either the turbo is shot or you have a humongous boost leak somewhere in the system. Or your don't have an accurate way of measure the boost.
But again I think the reason nobody has chimmed in is because you post is very vague.
Old 06-30-2010   #2
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
You sure you didn't mess up you boost gauge line and FPR line? Most boost gauges are hooked up with a "T" fitting, maybe you are running it with the FPR or disconnected one by accident?
