Old 07-03-2010   #7
Wizard
Re: WTB: FWD parts
The passenger side axles are the same for FWD/AWD. For driver's side, the FWD axles is a long single piece axle. AWDs had a intermediate shaft that bolted to the block and then used a smaller axle that went to that. It was part of the equal length axle setup. It was designed to reduce torque steer (why it was never in a FWD we'll never know) and to also help clear the T-case. You can run the AWD setup in a FWD though, just need the pieces.
You can use transmission or hp fuel hose for the brake booster line (make sure it's High Pressure).
Wiz
