Old 07-15-2010   #11
Re: Swifty's never-ending project thread!
Sorting out bugs, at my pace. I'd like to see if the things I've changed have really effected the tune at all, but I guess that takes some of shane's time and money. I guess we will see.
Set the 2-step up..6200rpms..wasnt enough to build boost. 6700 it SEEMS to want to start building boost. turbo is definatly spooling though. I'm curious as to either raising it some more, or try and get a little more "rapid bounce" in the limiter. in the AEM it's set to level 10 hard cut, ignition cut at 6700 rpm, fuel cut at 8200 rpm (I was told you want higher fuel cut then ignition so you dont go lean for that moment when it bounces at the top, since injectors can get a bit "laggy" in the way they spray..I dunno..was just told this). Any ideas from you tuning gurus?
