Old 07-18-2010   #2
Re: Help! Fuel injector issues
test the resistance of the injector the other way is to pull the connector off the bad injector while the car is running and see if the car changes.
You can do this now while you have a good injector in it to see if its the injector or wiring.
The swap you have done points to the wiring to check the wires on the back of the connector.
