Old 07-20-2010   #1
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
95 Eclipse GSX with 2gb conversion, 5 speed.....$5400
Up for sale is my 95 Mitsubishi Eclipse GSX, this is the turbo all wheel drive model! It has about 106,xxx miles on it and runs excellent. The Manual 5-speed transmission is in great shape and does not grind, the clutch has about 15,000 miles on it. The reason I am selling this car is because I have been wanting to buy an evo for quite some time and I am finally able to afford one. I have priced the car fair, don't try and low ball me it won't happen. The car is located in Duluth so if your wanting to come check it out, keep in mind its about a 2 hour drive. I drive the car everyday and would trust taking it anywhere!
Body:
I bought the car from its previous owner out of South Dakota so it is pretty clean since they don't salt their roads. The paint is still shiny, it has the complete 99 body installed and painted. This includes: 99 style front bumper, side skirts, headlights, rear bumper, spoiler, and door panels. The car looks great and. Overall I would say the car is a good looking car, the body is pretty clean without any major dents or scratches. It has nice 17" rims with very good low profile tires also. CLEAN TITLE in hand.
Maintenance:
The timing belt was replaced about 15,000 miles ago(very important on these cars), serpentine belts were replaced about 3,000 miles ago, new valve cover gasket, new thermostat, oil was changed less than 500 miles ago with mobil 1 synthetic. The entire driveshaft was replaced about 2 weeks ago by Driveline specialists in Duluth, they did a great job and the car rolls smoother than ever. The fluids in the rear differential were replaced with shockproof 75w-90. The oil in the transfer case and the transaxle were also replaced by gm syncroshift. Come check it out, you will love it!
Engine:
This eclipse still has the stock 7 bolt 4g63t motor, no signs of crank-walk whatsoever, I have compression tested it various times while i've owned it and it is great, no coolant or oil leaks, starts up everytime, like I said I drive this car everyday. It has a few modifications including a 14b turbo that has no shaft play. It spools up perfect to 15 psi without any smoking or any boost leaks. It has an APEXI 3" exhaust and down pipe, injen intake with K&N filter, AEM (i believe) AFPR, an almost brand new VR-Speed factory HUGE front mount intercooler with short route piping, Greddy Blow off valve, AutoMeter Boost and air fuel gauges mounted around speedometer, I'm sure there are a few more things that I am forgetting. The engine is great, there is a ton of money in parts on this car, not the cheap ebay junk!
Bads:
It has a cracked windshield
Could use a tiny bit of paint work where spoiler holes were filled.
If your interested feel free to give me a text or call anytime at 218-343-4642, don't bother emailing...
I am located in Duluth, MN although I do make frequent trips to the Blaine area. Don't contact me if your not willing to drive, no test drives without cash in hand. I'm sick of all the high school kids...
218-343-4642
Im asking 5400 and am open to reasonable negotiations.
Name:	eclipse front.jpg
ID:	10346   Click image for larger version
Name:	eclipse front2.jpg
ID:	10347   Click image for larger version
Name:	eclipse right.jpg
ID:	10349   Click image for larger version
Old 08-01-2010   #2
bigboostingst
Drives: AWD Spyder
Re: 95 Eclipse GSX with 2gb conversion, 5 speed.....$5400
All PM's replied to...sorry I haven't been on here for awhile
Old 08-04-2010   #3
bigboostingst
Drives: AWD Spyder
SOLD, Thanks mitsustyle.com! Enjoy your new car Ryne!
