Old 07-25-2010   #9
Re: how do cam shaft dowl pins snap .. ?
The cam bolt loosened up, if the bolt is torqued properly it is the friction surface of the cam gear and cam that keep everything in line. This is a case of if you have an engine still running after the factory warranty or a ton of miles it might be a good idea to check everything over.
