Old 08-16-2010   #13
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: What to do next??
So just got done doing MBL test. And the only thing that is leaking is the throttle position sensor. It leaks pretty good. I couldn't actually find it, but i could hear it so i used some warm soapy water and sprayed all around every connector and hose fitting. And so far that is the only place that bubbles up. Could that cause this problem? Thanks.
i forgot that it was leaking through the valve cover vent. i capped it and it stopped
