Old 09-07-2010   #11
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Re: Another 2g project
Well I haven't updated this in a while, the car is up and running now after its fair share of first start up issues I have all the leaks and every thing sorted out. The only problem i'm having now is I'm getting alot of hesitation/misfires while cruising at part throttle. I've tried new plugs, new wires, swapped coils, swapped transistors. Im going to add some ground wires from the block back to the battery and from the sensor grounds to the battery if that doesn't take care of it the next thing is the CAS.
Jungy is offline   Reply With Quote
