Old 09-10-2010   #16
Re: 880s, maft translator, and e85 = workable
I have run 880s on E85 with an SAFC on a 16G/stock SMIC car. It worked decent enough, we couldn't go crazy with the boost like usual on E85, because it would knock bad above 20psi with the horrible stock SMIC on there and no timing control. The MAFT is a shitty tuning device though, I would take a 2G MAS and SAFC over a MAFT. Like John said 880s on E85 are like running 600s on pump/race gas. The E85 can handle more timing, so it should work even better than 600s on pump gas and if you are able to raise your boost/airflow up enough the timing will drop with it.
