Old 09-13-2010   #11
Re: beaterX project thread
Weekly update? Prototype manifold and drag racing!
Caveots: I don't work for MAP; this is an unbiased review by a car guy that wants nothing more than to make his car faster.
I let MAP borrow my car for a few days for their lil-welder that could (Chris is amazing) to fab up a prototype for their tubular exhaust manifold for the Evo X. I'll be beating the piss out of the car and just generally making sure the thing works so that the product is as good as it can be. There may be some minor revisions but the manifold you see here will be available either cleaned up or ceramic coated.
The thing is really a work of art, I will get more pics of it. The flanges used are amazing CNC pieces and the welding is out of this world. There's not much to say about the product itself other than its built right here in the USA and the quality is nothing short of world-class.
We kept the testing *extremely* simple on this. My X was tuned only a few weeks ago and the tune was untouched throughout the entire process. The car put down 4-5 good baseline pulls before we yanked the stock manifold to get the prototype on. After it was locked and loaded, guess what? We made more dyno pulls! I made them do several to be sure but the results consistent and correct.
Holy crap that can't be right! We poured over the numbers and other dyno plots. The truth was right there in front of us. The car lost about 400rpm in spool. I was a bit disappointed by this to be honest but I feel like it could be helped with some tuning. This manifold utilizes 1.25" runners to avoid being too laggy.
Power. From 6500-8000 the car gained 35+whp. From 7000-8000rpm the car is up a solid 40whp! I was absolutely in shock, this couldn't be possible! But it was...it SO was!
http://www.youtube.com/watch?v=QK-vA7jSdVE&hd=1
Now, the awesome part. Projects like this can take some time, but I told the guys at MAP that I was going to the drag strip this Saturday come hell or high water. Things ran late as they always do, but they made good on their promise. Friday night at 7pm the car was on the rollers for this test and then I went home to get ready for the trip to the track the next day.
Driveability. The car honestly doesn't feel any laggier, maybe a bit in 2nd gear but cruising around the car feels the same, until you are WOT and in the upper rpm. The car feels SO much better now, its still just as smooth and fun but damn it just rips up top! The car is starting to make enough power now that you start to get that floating feeling when staying in the powerband.
Reliability. I have honestly been the eternal skeptic on tubular manifolds. They all crack, it's easy to just say that. I'll update this thread down the road and let you know how it hangs in there. My hopes are *very* high that it will last for years to come!
*edit* current power mods:
aFe intake w/ perrin inlet
custom 2.5" UICP
custom 3" pte core fmic (not much bigger than stock)
MAP tubular header
CBRD BBX Turbo
MAP O2 Elim Downpipe
Megan Testpipe
Magnaflow Catback
hallman mbc
dw 800cc injectors (BP 93 oct)
So with that said, I packed up the car, woke up around 5am and hauled my arse out to wisconson (near Eau Claire). On the previous trip to BIR on stock turbo/pump gas was pretty consistent 13.3's@106mph and one 13.1@106.
http://forums.evolutionm.net/drag-ra...ounds-bir.html
Added ACT HDG6 clutch, dw800's, CBRD BBX, MAP o2 elim downpipe, and MAP prototype tubular exhaust manifold. This is a full-weight X with a full tank of gas, street car, sumitomo tires, just out here to have FUN!
Headed out to Rock Falls Raceway (aka slippery falls) in WI saturday for a test & tune.
This was a little more expensive than a sport compact day but MAN you could freaking hotlap all day if you wanted to!
First run: 12.7@115mph (as I rolled off the street, rolling through water box)
Second run: 12.55@113 (slightly improved 60', rolling through water box)
Third run: 12.51@115.0 (dropped tire pressure to 24psi, still rolled through water)
At this point I knew if I could get my 60' down I could run a 12.4 or maybe 12.3? I made the mistake of saying that to a few friends and that then became my goal for the day.
I was trying to go around the water box from third run on but the track officials wouldn't not cover the entire area with water so it was tough...finally go that resolved and they made room to go around....fourth and fifth runs I dropped the tire pressure to 20psi, raised the 2-step to 6500rpm and finally got to go around the water....BOGGed the first run bad and ran a 12.9 then the fifth run I didn't bog quite as bad (slipped clutch more) but missed the shift to 2nd so ran a 13.1.
I was frustrated as all getout but then I decided to man up and raise the 2-step to 7000 to try and get the bogging issue behind me.
Sixth run I finally didn't bog, got a decent 60' (low 1.8x) and overall a pretty clean run. 12.403@115.9! I was ecstatic!
The weather was beautiful and I had reached my goal in my mind and was ready to hang up my helmet for the day. After staring at empty lines for about 30 mins and watching some pretty fast cars I received a txt from my wife Anna (I had been updating her and a few others) 'keep going!!!!' ....how could I turn down a woman's request like that? So I manned up and hopped back in the car for run 7.
Run seven: 12.3@116.7 Probably about the cleanest run I could pull off and I had a smile on my face the whole way.
With the new manifold this car has really come into its own. Pump gas only, stock cams (fully stock longblock for that matter!), basic power mods and the BBX the car is a freaking blast on the street, and heated leather seats with cruise control to make the two-hour trip to the track and back
