Old 09-22-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: N/A motor in Turbo car.
^^^All your info is pretty much incorrect..
You can just swap the flex plate, if they're both 6 bolt engines.
The NA engine will have higher compression, but other then that it will be fine since it doesnt sound like you plan on modding the car.
Just make sure you connect all the sensors (dont forget the injectors, fpr, knock sensor) just like it's a turbo engine and you'll be good to go.
-1990 Mitsubishi Cyborg 4WD-
