Old 10-07-2010   #23
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Why do I keep blowing turbos?
Originally Posted by CarPsyco84 View Post
heh, Im sure its well over 100psi till warm, then only slightly over 100psi...
For the sake of having some raw numbers, I'll put a gauge on it and take some readings.
Obviously running SAE30 vs a multigrade will be thicker when cold, but the car is not driven cold (50* ambient temps is about the lowest the car has seen in years). Once warm, a 30 weight is a 30 weight, regardless of it's cold starting properties.
I'll report my pressure findings.
-Sebastian Vettel
Tags
no one likes the tuna...
