Old 11-08-2010   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: SERIOUS PROBLEM (Jake Vogel/TKR Mark)
Video of end play from the center diff...
http://www.youtube.com/watch?v=-ALW-U3GQDc
Originally Posted by shoutbox
Old 11-09-2010   #2
Are you sure the transaxle case adapter is still tight up to the transaxle case? I have had the transaxle case adapter break free of the transaxle case when taking the input shaft and intermediate shaft lock nuts off.
It the video the transaxle case adapter looks like its in contact with 5th gear. For how loose that is in the video there would have to be no shim, worn/bad bearings, if the two housing are tight.
And from what I recall its a difference in the 5th gear hub/slider from a early 1g to the late 1g and into the 2g they switched to use the cast iron 5th/rev shift fork. I am not sure but I would guess the 5th/rev shift rails are different also.
Any time I install a 4 spider center diff its easy to look inside to see all 4 spider gears.
Also at that point why not check the center diff end play per the factory manual and tell us, it was X off?
As for the Evo 3/4th gears check out this page, there is a lot of good DSM tranny info.
http://www.jackstransmissions.com/pages/tech-articles
You will notice the EVO 3 and 4 gears have 4 holes for tabs off the double synchro, it is easy to look in from the side of the gear set and see if there at tabs going down into the 3/4th gears. If they are not present its not an evo 3 or 4th gear.
http://www.jackstransmissions.com/pa...-synchro-rings
