Old 12-20-2010   #6
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Evo9 Clutch Install Problems
We've identified it as being the left front axle, seems as if the knuckle at the hub is either damaged or destroyed, with it assembled you can turn the hub by hand and it's crunchy and the axle won't turn.
Anyone have a front driver side axle and hub assembly available? We need both because the axle is seized inside the hub.
Thanks for the help tonight matt.
We have the axle apart, and end of the axle that fits into the hub is disconnected and the splines on the shaft part of the axle are damaged. So I picked up an axle from Jim (thanks Jim!) tonight and we are going to try and combine the to axles to get it going again. I think we should be able to make this work and hopefully get my car back on the road tomorrow! Otherwise I'll end up trying to get the last part of the axle pressed out of the hub/knucle and see where we can go from there.
I know how I feel about this for my own car, but looking at vehicle compatibility, I can likely get my hands on a Precision hub assembly (seems this is shared with the 3/S VR4) at $190, and I'll look into an axle, which would be a brand new part, but would likely have to be ordered from the manufacturer. Text me tomorrow and I'll take a look.
I'll keep you posted, but I think I can get one from Mitsu for like $130, it needed.
