Old 12-20-2010   #2
Re: 90 Laser
This is in the wrong section, this is a basic tech question. But anyways, does it blow through the vents in any other position? If it does, the ducting on top of the blower cabinet might be missing, or the flapper door isn't working. Basically, there's a large plastic box with the blower fan in it and a flapper door directs air to the low, dash or defrost vents, they are cable activated. If you take off your glove compartment, you'll see 90% of it, look to see that the black-sheathed cables are attached to the flapper door rods, ther are on the outside front of the box, you'lll see them right away. Make sure they move when you operate the heater controls. Report back what you find. Good luck.
