Old 12-28-2010   #5
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Re: 90 laser stock high rpm studder
ah boost is at 12psi then creeps up to 15 then back down i took it out again to night when there was open roads and did a 5th 50-100 wot and really tried to listen to the engine on what it was doing
it only dose it under a load so like 1st 2nd no issues then 3rd it starts to then 4th runs like its missing at 1/4 th to 1/2 then i hit 5th and its the same or worse to get it up to speed it has to be in low boost like 5 or less
i have no way of telling what afrs are i do have a wide band but its in my talon i dont want to pull it out i know its not a boost leak i just took everything apart and put silicone on my pipes and sealed it up
is the check engine light suppose to flash when there is detonation or is that dsm link only i do have dsm link in the talon could i pull my 91 talon ecu and put it in my 90 laser try to find what is going on ?
