Old 05-29-2004   #1
Kougar
Drives: 06 RSX
I just put in a SPEC stage II clutch in my quest, and i did it myself. Thing is, now it doesn't go into gear. When the car is off, the shifter moves in and out of gears fine, so the shifter has to be in right (i have RWD also - direct link).
I got it in reverse once, i dont know how - i might have pulled up on the shifter. It shot me backwards until i put it back in neutral. I can't remember if i even had the clutch out when it shot me.
It will not go into any gear, and it grinds reverse like hell.
I had a leak of DOT 3 before the clutch, never found out what it was though. I'm thinking master/slave cylinder, because that's what my new problems points to.
I've already bled the clutch (no help), the pedal is fine, and that's what i've done so far.
